Correct vinyl top?
Old September 9th, 2018, 03:46 PM
Platinum69's Avatar
Correct vinyl top?
Was the original vinyl tops on 1969 442 padded or unpadded? Looking at ordering one. Any recommendations on where to get it from? Thanks
Platinum69 is offline
Old September 9th, 2018, 04:14 PM
No padding. OR what you can do is make it into a two tone paint job. That was also a factory option using the same roof trim. Only major difference is no problems with rusting under the vinyl. That being said I do like the look of vinyl tops. They are expensive, no to buy, but to install. It also requires you to take out the interior rear trim so the moldings can come off to do a proper job.
Allan R is offline
Old September 9th, 2018, 04:29 PM
Here's some followup info for you about the 69 442. The first one shows the recommended color choices for two tone paint. The second one is the SPECS listing showing the 442 standard features and RPO's.
Allan R is offline
JAXX455
Body work
May 16th, 2018 12:58 PM
midnightleadfoot
March 27th, 2018 08:57 AM
My2nd 69 442
Body work
October 27th, 2016 07:39 PM
safray
Care and Appearance
April 29th, 2016 09:10 AM
72CUTTY
November 2nd, 2007 02:56 PM
Quick Reply: Correct vinyl top?
