Conv Top adjustment
Old Jan 24, 2010 | 04:49 AM
Ron King's Avatar
Conv Top adjustment
My 72 Cutlass had a new top installed before i bought it.It has some wrinkles on each side .How do i go about correcting this?
Old Jan 24, 2010 | 07:24 AM
Lady72nRob71's Avatar
Ron, adjustment may or may not be possible. If you could post some somewhat-close pictures of the wrinked areas, we could evaluate it better.
Does the top open close and seal all around properly?
Old Jan 24, 2010 | 09:49 AM
Ron King's Avatar
The wrinkles are located right behind the rear windows(c-pillars) and run on the horizontal,about 3 to 4 ".By the way,my 72 is white with white and black interior.
Old Feb 9, 2010 | 03:41 AM
CHRISH8846's Avatar
I installed my top at home and I can tell you it takes a lot of fiddling for a novice to get right. The problem you have is with how the top is mounted to the trim stick. It has too much stack at the corners,that said unless you have done it before it is a PAIA is remove and readjust and retack. I had mine out no less than 5 times before I got it right (you also need to factor in removing all the rear seat trim and cushions). If you have never done it , it needs to go back to the trim shop to get right.
Old Feb 9, 2010 | 03:42 AM
CHRISH8846's Avatar
I installed my top at home and I can tell you it takes a lot of fiddling for a novice to get right. The problem you have is with how the top is mounted to the trim stick. It has too much stack at the corners,that said unless you have done it before it is a PAIA is remove and readjust and retack. I had mine out no less than 5 times before I got it right (you also need to factor in removing all the rear seat trim and cushions). If you have never done it , it needs to go back to the trim shop to get right....
Old Feb 9, 2010 | 04:22 AM
IMHO this is one that is worth paying an expert to do. It's tricky and one adjustment leads to others. I've seen people really mess up and I've seen people who know what they're doing make it look easy. Ya kinda got to Zin "Be the Top" nanananaaaaaaaaaaaa
Old Feb 9, 2010 | 05:17 AM
Even the shop that did mine was supposed to have been an expert, but it stretches too tight and does not retract enough to get the boot on.
I will fix all that with the next top...
Old Feb 9, 2010 | 05:23 AM
When it's cold, the only way I can get my top locked down is to park it in the sun [dark blue top] and turn on the heater to get the top soft enough enough to stretch into place
Old Feb 9, 2010 | 06:01 AM
Sounds like yours is way tighter than mine even!
I can latch it at 30* with the windows lowered some and hitting the switch with one hand and latching the left with the other hand. Right one grabs easily after.
In summer, window lowering is not needed.
Old Feb 9, 2010 | 07:08 AM
While we're on the subject. I don't know about 72's but 69's have only one pin in the top. On the drivers side. I've often thought that odd.
Old Feb 9, 2010 | 09:17 AM
'72's have one pin also.
One is an odd number, you are right...
Old Feb 9, 2010 | 09:35 AM
CHRISH8846's Avatar
You mean locating pins for the top?? mine has two. It' a 71.
Old Feb 9, 2010 | 09:51 AM
Bluevista's Avatar
Registered
Why would a '69 have one, a '71 two, and a '72 one latching pin??
I'll have to go get a ladder and climb up on the lift and see how many my '68 GTO has.
They probably did it so only one pin would never align right.
It is a pain sometimes with two and people were probably coming in for service too much?
I got my GTO from San Antonio, Texas in '95 and I had the PO take it to a Mexican trim shop for the top before it was shipped, the top was a deal?
The thing fits, looks and works great to this day.
I should have had a diamond tuck and roll interior done too.
It would have only been another 75 bucks.
Old Feb 9, 2010 | 10:03 AM
Now this is downright wierd
Tedd Thompson
Aug 11, 2013 01:51 AM
66olds98conv
Ninety-Eight
Mar 21, 2013 12:52 PM
The_German
Aug 28, 2011 08:18 AM
ROTORHEAD
Sep 9, 2010 04:34 AM
