Central PA Shop Recommendation
Anyone know of a good shop you trust in Central PA (Lancaster)? I need some work on my 1968 Cutlass. Possible trans rebuild, power steering pump replacement, tuneup. It died on me after a few cruises around the neighborhood last weekend. I noticed it idled very slowly at stop signs, almost died. And then finally did. Couldn't’ get it started again. Got it back in the garage and let it sit a few days and it started right up again! Not sure what to look at first.
Any recommendations would be welcome!
Need more information; has it been running fine up until then?
Clogged fuel filter, bad fuel pump, boiling fuel causing vapor lock, etc.???? It could be any of those so provide as much info as you can.
As far as a shop in general, most NAPA auto care centers can get you headed in the right direction.
Thanks!
