Cam installation tools
Old Feb 3, 2023 | 06:30 PM
dav45's Avatar
After ordering a couple on sets, i still haven't found a cam bearing installation set that has the correct billits for a small block olds. Anyone know who makes a set without tearing up the bankbook?
Old Feb 3, 2023 | 09:03 PM
edzolz's Avatar
When I had access to a good lathe, I made my own from aluminum round and 1/2 inch all thread. You have to have one die for each size bearing.
Old Feb 3, 2023 | 10:47 PM
dav45's Avatar
Problem is brake lathe won't accomidate. Don't want to wait 3-4 months for machine shop. Most sets are for chevvies. Ferds or mopars. Thinking about using rubber freeze pulgs along with bearing races as guides.but cam bearings are getting hard to find, so it's a long shot.
Old Feb 4, 2023 | 10:34 AM
BillK's Avatar
I have never used anything but the good old fashioned K-line tool with the expandable arbors with o-rings on them. They work on virtually anything. Mine is probably 40 years old.
I bought one of the BHJ tools that uses a big screw to pull the bearings in but to be honest with you it is more of a pain than it is worth. I bought it to do the late model Hemi bearings which are hard to do with the old type tool but that is about all I use it for.
https://www.ebay.com/itm/22516474411...JPuxrLSBR2cxjM
Old Feb 4, 2023 | 08:52 PM
dav45's Avatar
I used to have a k-line(bought it in early 70's) but buddy had it when he passed on. Haven't been able to find another one. That is the thought behind trying rubber freeze plugs with bearing races, which is not working out.
Thank you for your input. Mel a 9 7 88lss,73 98 coupe-one owner,59 elcamino,60 impala.
Old Feb 5, 2023 | 02:26 AM
Tri-Carb's Avatar
K-Line cam kit in question?
K-Line Cam Bearing Installation Tool (1.120" - 2.690") | eBay
Old Feb 5, 2023 | 06:34 AM
Originally Posted by Tri-Carb
Yes. That's the set I have also. The expanding mandrels also come in handy when installing bushings in automatic transmissions.
Old Feb 5, 2023 | 09:01 AM
Post #4
Old Feb 5, 2023 | 03:24 PM
BillK's Avatar
The Lisle tool is basically the same except it uses a big flat band instead of the o-rings. I know plenty of guys that use them too.
Amazon Amazon
Old Feb 16, 2023 | 11:39 AM
dav45's Avatar
Gave up and ordered a lisle. All this for a ragged ol c-10, but the big block in it wore out. Thank you to all who responded. Mel a..
dstaff
Jun 30, 2022 10:29 AM
lukestmz
Jun 10, 2022 11:07 PM
lukestmz
Apr 19, 2022 11:42 PM
bigrbandit
Apr 11, 2019 07:32 PM
mother$hip89
Feb 15, 2018 08:59 PM
