a/c vents not working
Old Jul 9, 2014 | 06:29 PM
KDV's Avatar
KDV
Factory A/C '72 Cutlass Supreme - no actual A/C anymore
I've got air blowing through the floor heater and the defroster but not through the dash vents.
Vacuum canister on the firewall's hooked up.
Any clues as to where I should start investigating?
Old Jul 9, 2014 | 06:41 PM
Make sure that the vacuum canister isn't leaking and that you actually have vacuum going into the system.
After that, look at the mode door, diaphragm, and hoses for the A/C, and also at the A/C selector valve.
Old Jul 9, 2014 | 08:09 PM
oldspackrat's Avatar
This may sound dumb, but start the car, turn the radio & fan off & stick you head under the dash near the heater outlet. You might be able to hear a vacuum leak somewhere? Also, slide the mode leverthrough each position & listen for a leak in any one of them?
Old Jul 10, 2014 | 05:07 PM
KDV's Avatar
KDV
Thanks for the help!
Old Jul 12, 2014 | 02:55 AM
tfatboy's Avatar
Mine did the same thing. Turned out my a/c hoses had desinigrated behind the dash
Old Jul 12, 2014 | 10:07 PM
KDV's Avatar
KDV
Thanks for the input!
I'll start digging into this right after the National Street Rods the first weekend of August.
I've got my fingers crossed that I'll finish the front end rebuild before then.
I'm a little apprehensive about pulling the dash apart without breaking anything. Doh!
Old Jul 15, 2014 | 05:59 AM
tfatboy's Avatar
No doubt! Maybe you can reach up in there without taking the dash all apart. I just happened to be having my dash pad redone when I saw those hoses all brittle and falling apart
Old Aug 7, 2014 | 09:49 PM
KDV's Avatar
KDV
Got really lucky with this little problem.
The 1/8" vac line coming off the canister was perforated in the engine compartment right before it goes through the firewall.
All the lines under the dash and the diaphragm for the vent door look relatively new.
silverriff
Feb 13, 2008 03:59 PM
black betty
Dec 21, 2007 12:13 AM
70redvert
Dec 3, 2007 07:26 PM
Calvin.Norris
Nov 27, 2007 06:08 PM
<KEN>
Sep 22, 2004 08:39 PM
