Bolt on exhaust options | Dougs headers
Old Feb 10, 2020 | 09:56 AM
Brians1's Avatar
Members,
Im about to be done with my 455 build and I want to find the best bolt on exhaust system for my headers, I have the D741-B set from Dougs headers.
Hoping there is some knowledge of a kit that I can just bolt on without needing custom work/cutting/welding/etc.
Thanks for the time
Old Feb 10, 2020 | 11:03 AM
Perkolator's Avatar
You could always use a universal exhaust pipe kit from like Summit or similar; they make a clamp-together kit too, but I'd assume there will be at least some cutting/welding/splicing to get it all to fit since it's you know, universal.
This is the route I'm taking right now in attempt to get dual exhaust on my Delmont 88 - got a Summit 2.5" piping kit to weld up
Good luck!
Old Feb 10, 2020 | 12:40 PM
70cutty's Avatar
Beer Connoisseur
Take a look a pypes, great quality and they fit with very little (if any) modification.
https://pypesexhaust.com
Old Feb 10, 2020 | 12:51 PM
Brians1's Avatar
awesome - thank you
Old Feb 10, 2020 | 02:11 PM
oldsmoboogie's Avatar
I am installing the summit 3 inch kit on my 72 at the moment. It does take some cutting but the fit is pretty good. I had a flow master 2 1/2 inch kit on it before that fit better. A friend has the magna flow kit that fits well but it’s expensive. All 3 kits require some cutting to fit but have slip fit joints and can be clamped.
Old Feb 10, 2020 | 02:43 PM
Brians1's Avatar
Do you have the part number you can send me , I wouldn’t mind researching to see what kind of parts I can assemble. And you also have long tube headers ?
Old Feb 11, 2020 | 01:17 PM
Brians1's Avatar
I called Flowmaster earlier and they let me know that all of their kits for the Olds that say "Header back" means they are made for Long tube headers and that i would only need the 3 bolt flange connector, which Dougs headers includes so this took a lot of mystery out of the fitment and also opened up the door on options.
1 option:
Dougs headers:
https://shop.dougsheaders.com/doug-s...l#.XkMZrpNKjUK
paired to Flowmaster:
https://www.holley.com/products/exha...er/parts/17200
Old Feb 11, 2020 | 07:10 PM
70cutty's Avatar
Beer Connoisseur
Flowmaster 3" kit has horrible bends over the rear axle. Both Pypes and magna flow kits fit much better.
Old Feb 11, 2020 | 08:19 PM
Brians1's Avatar
OK great to know thank you
geoff442
Jan 4, 2017 08:55 AM
wr1970
May 25, 2016 12:33 PM
billmerbach
Nov 29, 2014 08:08 PM
ralsy
Jan 5, 2011 05:10 PM
nohn
Oct 26, 2007 06:21 PM
