Best way to rebuild my 1971 350 Rocket
I still own my 1971 Cutlass Conv that I bought in 1984, it was my 1st car. Unfortunately I stored the vehicle away with a blown head gasket. I discovered moisture damage, top & bottom, & i am looking to rebuild my 350 Rocket. Any advice on ways I can squeeze the most out of my 350, without breaking the bank. Any suggestions are greatly appreciated. Thanks for your time & have a happy & safe 4th of July.
I think reliability is as important as performance. Good machine work and quality parts. Check all engine bay wiring while the engine is out. Radiator should be as new. Carb restored. Performance is great, but being able to drive and enjoy your convertible is priceless.
bobby
One thing that is critical is the piston selection, and Mark will make sure you get the right ones. The commonly available cast pistons are short on compression height and the engine will end up with less compression ratio than what you expect, but most forged pistons are the correct height so they don't have this issue. Also, do not use the "1971-1972 factory replacement" pistons as they have HUGE 24cc dishes in addition to being too short and will end up at less than 8:1 compression ratio.
You search for his username in the upper RH corner like you would do for anything you want to search for.
cutlassefi
cutlassefi
Follow proper procedure
In proper order , have checklist & someone assist & double check
Learned early on this pretty much guarantees success
Dont be in a rush
Specs & tolerances from engineers produced outsanding , dependable powerplants & still do
Its perfectly fine to be nit pickin **** retentive as you want to be with your self when assembling an engine
Know your limits & be reasonable...dont have to know / do everything
Their are things well worth payin someone to that does it all time
Have dedicated plan of action & matetials to get from where you are to where you will be & stick to it & dont stress out
Spent countless hours as a punk holdin flashlight & runnin for wrenches & all that is priceless...
Dont be in a rush
