Benefits to changing flex plate
Old Mar 28, 2014 | 02:42 PM
72Burning$$'s Avatar
Hell Olds Fam,
Im in the middle of rebuilding my 350 with performance parts and I was wondering what benefits if any would replacing the flex plate have?
Old Mar 28, 2014 | 02:46 PM
If it's just for the street and the flex plate is not worn and all the teeth are good, I see no reason to change it. If your going to race it I would go with a quality SFI plate.
Old Mar 28, 2014 | 02:48 PM
don71's Avatar
same but different
What are your goals? Do you need an approved piece for a racing class? The factory flex plate is probably just fine. But if you are going all out...
Old Mar 28, 2014 | 02:52 PM
thanks for the reply, i dont plan on racing, not on the strip at least but if a rice burner temps me i just might. For it being the original flex plate off a 72 it doesn't look to bad. Just wondering if there would be a great difference between stock or performance?
Old Mar 28, 2014 | 02:58 PM
as far as going all out... my 350 is bored .30 over with edelbrock performer heads 77cc, performer intake, comp cam camshaft, magnum rocker kit and a few other things. pretty much all the internals are performance upgrades.
Old Mar 28, 2014 | 03:19 PM
don71's Avatar
same but different
If you were going all out, you would have the assembly balanced with the flex plate of your choice.
If you didn't do that, no big deal. The factory flex plate sounds fine for what you are doing.
Old Mar 28, 2014 | 04:43 PM
The difference would be exactly zero. As noted above, the only reasons to change would be if a racing organization required an SFI certified one or if the ring gear teeth were damaged. Otherwise, don't waste your money.
72cuttys
Jun 28, 2014 11:03 AM
cam40
Oct 8, 2009 05:16 PM
joe_padavano
Sep 24, 2009 04:31 AM
canucklehead
Dec 2, 2007 08:16 PM
Clint Reno
Aug 10, 2003 10:03 PM
