Backing plates
Backing plates
I have been organizing every part that needs blasting and refinishing. I have my original front end pcs (1970 442) and everything on spindles is rusty. The backing plates are really rusty and was wondering if new reproductions are any different or fit well? Has anybody had any experience?
Since they are so rusty it looks like they may have been natural finish? can anybody verify this along with caliper brackets and other front end pcs like linkage (center link, tie rods and sleeves? Ive seen some different colors in restorations.
How about the rear backing plates, what color or finish were they?
I may have come across a post in the past that states color or finish of various parts (brackets, nuts, bolts) any info appreciated.
Yes, the rust will blast off but you will have some pitting as it looks like fairly heavy rust.
The caliper dust shields WILL have some serious pitting judging from the pic and I would expect the caliper mount brackets to be close to the same result.
Front disc dust shields (repro) are a clear zinc finish (ie -bright silver). Don't know about the fit but they appear to be fairly accurate and I've never heard any complaints about them. That is considered the correct finish for a resto even though the orginals were galvanized zinc.
Front caliper mounting brackets were/are yellow zinc (or cad)...gold finish. I've dealt with one set of these that were repros from The Parts Place and they scraped the inside of the wheel. Have read plenty of times about others having the same problem. You can grind off the offending corner (not a lot of grinding) but nicer originals would be the best option and then you wouldn't have to worry about some other problem on the repros. Finding some nice replating candidates may take some time but that's part of this game.
The repro dust shield may not have Delco Moraine stamped on them? Also the R and L along with the part number may not be on there. I would blast all the rust off and see what you have. Eastwood sales paint that mimics the correct finishes. It really depends on what you want to do with the car. Drive and enjoy you may want to reuse your original parts? Show the car, look for all good original good parts.
Thanks for info guys. Im gonna blast everything and see what it looks like? Just so I know, "backing plates" and "dust shields" are one in the same correct?
I plan on driving and showing, life is too short.
Can you guys shed any light on the correct colors and finishes of the other parts I mentioned? I dont recall seeing any original rear end backing plates that weren't black?
68442Convertible
Brakes/Hydraulic Systems
Jun 8, 2016 08:15 PM
68442Convertible
Mar 8, 2016 07:03 PM
