Anyone put a/c in their ‘67 Cutlass/442?
Old Nov 2, 2023 | 06:51 PM
Jon442's Avatar
Gearhead
My mechanic was looking at options for installing vintage air in my ‘67 442. Vintage Air does not offer a kit for that car. They do for a ‘67 Chevelle, and he thought he might be able to use it with some modifications. However, it does require removal of the right front fender and neither of us are OK with that. For those of you that have added a/c to your ‘67, what have you done?
Old Feb 3, 2024 | 02:15 AM
DC400's Avatar
Vintage AC
I used the kit from a 68 cutlass. Some modifications were made and right fender was removed to get it to work. If you call vintage A/C they will mock up the kit for you. I believe mine was first kit they did. We used suggestions from previous member to develop kit.
Old Feb 3, 2024 | 03:41 AM
Rallye469's Avatar
I don’t think you’re going to get around not removing the right fender.
Old Feb 3, 2024 | 03:54 AM
fleming442's Avatar
Agreed. Pulling the fender will make it much easier, however you may get away with just pulling the inner as to not disturb panel alignment.
Old Feb 3, 2024 | 06:46 AM
jmcghee's Avatar
another option
The factory manual tells you where to drill a hole in the inner fender . This allows you to access the lower bolts, that hold the heater, blower cover. However I dont know if you can install the vintage air, wiithout removing the inner fender. The outer fender in any case does not have to come off
Old Feb 3, 2024 | 02:56 PM
Rallye469's Avatar
Not sure what it’s like on a 68…but removing an inner fender on a 65 is a mess.
Old Feb 4, 2024 | 03:48 PM
oldsrush's Avatar
Gearhead
I have been toying with installing a/c on my 67 also. I'm thinking 67 Chevelle under the dash assembly from Vintage, a factory a/c bracket and Vintage has a compressor that will fit it. I would paint it black. The hardest obstacle I think is finding decent factory a/c vent ***** for the ends of the dash.
aqua67w30
Paint
Sep 14, 2022 03:51 AM
jcdynamic88
Jan 31, 2022 05:03 AM
66 W 30
Aug 21, 2021 10:36 AM
sammieolds
Jul 1, 2014 05:08 PM
springbryan
Apr 26, 2014 04:27 PM
