Any ideas
Old Jul 31, 2009 | 06:03 AM
jagmans64olds's Avatar
Any ideas
I was wondering if anyone knew if I could use floorpans from a 1964 Impala in my 1964 Dynamic 88. I am having a hard time finding any decent used pans with out any rust on them. I have heard that alot of the B Body parts are interchangeable. Any ideas about this?
Old Jul 31, 2009 | 06:36 AM
Oldsmaniac's Avatar
Most likely, yes. I used 59 chevy pans for my 59 98. fronts were right on but since it was a 98 with longer wheelbase the back floor pans were shorter.
Old Jul 31, 2009 | 07:42 AM
Doesn't the Impala have an X frame? I doubt those floor pans would fit on the D88 with a perimeter frame.
Old Jul 31, 2009 | 08:29 AM
Oldsmaniac's Avatar
I am not sure if the 64 Impala has the X frame as my 59 does. I was ***-u-me-ing that both 64 models had the same frames.
Old Jul 31, 2009 | 08:54 AM
Oldsmaniac's Avatar
If the frames are not the same you may want to look at the 65 floor pans if they are produced.
Old Jul 31, 2009 | 08:58 AM
Thanks for the info. Will check on the frame on the impala to see if it will work.
Old Jul 31, 2009 | 09:08 AM
Here are some pics. for you to see.
Old Jul 31, 2009 | 09:19 AM
csstrux's Avatar
64 Impala DOES have an X frame. If the delta is a perimeter they will probably not be common.
Old Jul 31, 2009 | 09:31 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Yes. Lesabres have an X frame as well.
Floors are floors in my opinion. I used 67 Cougar floor pans in my 85 delta. Cut, weld, grind, repeat. Once it looks good enough, you're done.
Old Jul 31, 2009 | 09:42 AM
Originally Posted by csstrux
64 Impala DOES have an X frame. If the delta is a perimeter they will not be common.
And my 64 J88 does have a perimeter frame (as do all the 64 B/C body cars from Olds).
Old Jul 31, 2009 | 10:04 AM
csstrux's Avatar
Odd that they did that...Did Buick use a perimeter frame as well? I wonder if the pans wouldn't be similar in a 65 then even if the shells are dramatically different.
Old Jul 31, 2009 | 11:52 AM
csstrux's Avatar
Guess this answers my question.
Snowdog
Nov 8, 2009 10:27 AM
#1CutlassSupreme
Jan 4, 2009 06:02 PM
southcarolina803
Aug 6, 2008 06:04 PM
Luckyme1870
Aurora
Jul 26, 2007 05:05 AM
Oldsmofjord
Jul 26, 2007 01:21 AM
