89 olds cutless supreme els 2.8 6cylinder
i have replaced all the fuel related items and still having problems. The engine starts runs for 20-30 minutes and then dies. Then I can't start it again for almost an hour. Replaced the fuel pump relay it's still doing the same thing. Any ideas on what's going on here?
Does it fire off of carb cleaner? Could be a possible coil problem with starting/dying and then needs to cool down in order to run again.
http://easyautodiagnostics.com/gm/2....n-coil-tests-1 this not 100% of what you need but should be able to walk you through diagnostics.
FYI cutlass![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
Pat
FYI cutlass
Pat
bigalive
December 21st, 2010 06:52 PM
bigdaddyolds
February 12th, 2010 11:49 AM
