89 olds cutless supreme els 2.8 6cylinder
Old May 20, 2017 | 06:35 PM
G-rag's Avatar
i have replaced all the fuel related items and still having problems. The engine starts runs for 20-30 minutes and then dies. Then I can't start it again for almost an hour. Replaced the fuel pump relay it's still doing the same thing. Any ideas on what's going on here?
Old May 21, 2017 | 07:01 AM
1970cs's Avatar
Lansing built
Does it fire off of carb cleaner? Could be a possible coil problem with starting/dying and then needs to cool down in order to run again.
http://easyautodiagnostics.com/gm/2....n-coil-tests-1 this not 100% of what you need but should be able to walk you through diagnostics.
FYI cutlass
Pat
bill curnick
Oct 15, 2016 08:28 AM
bill curnick
Oct 12, 2016 05:27 PM
bigalive
Dec 21, 2010 06:52 PM
bigdaddyolds
Feb 12, 2010 11:49 AM
tony73mach1
Jun 8, 2007 09:44 PM
