72 cutty exhaust ?????
Old Jun 22, 2009 | 05:48 PM
0590trab's Avatar
Hi, guys I have a 72 cutlass w/455 bored .40 over, L2323 pistons,big vavle C Heads,comp cam 280H cam .480 intake -.480 exh. (.280 duration ) Do I need headers or will the original 455 dual exhaust work
with this setup. ..........thanks in advance for any and all help....
Old Jun 22, 2009 | 07:10 PM
svnt442's Avatar
It all depends on what you want out of the car. I'm guessing you have the W/Z manifolds. They flow well for a stock manifold.
Headers do have benefits for sure, but you don't need them.
Old Jun 25, 2009 | 01:41 AM
0590trab's Avatar
Thanks alot, Randy, I'm not racing or anything, I just want a little more power, It looks like the header installation is a real task, just wondering it the benefits are worth it ???.
Old Jun 25, 2009 | 06:01 AM
BIGJERR's Avatar
I bleed Oldsmobile
Putting the headers on is usaully easyer than getting your old manifolds off.........Power gains are pretty good going from a restrictive stock manifold system to the free flowing set of headers...........
If you go to headers I can give you a few tpis to make it a smooth process.............Jerr
Old Jun 25, 2009 | 07:30 AM
A72CUTLAS's Avatar
Tha' Big Dog
I'd like those tips also, I've got my headers, H-pipe, and mufflers together, just need to paint headers for rust-block.
Old Jun 25, 2009 | 07:38 PM
0590trab's Avatar
Thanks, BigJerr, I'm going with the headers, is there a certain type that you would recommend, and any installation tips will be much appreciated
thanks in advance........travis
Old Jul 1, 2009 | 06:28 PM
BIGJERR's Avatar
I bleed Oldsmobile
Sorry for the delay........I'Am sure others can add some pointers also but the first one is dont try to put the P/S header on with the oil filter pick up on.......Set the header up in postion then reach up and bolt the oil filter pick up housing on,Not easy but makes it a smoooth deal to get the header up and in place,Your brake proportion valve might have to be moved......Some headers hit it some dont,I made a new bracket and just moved it up away from the header(Hooker 1 7/8 need the valve moved) If you go with a off brand with the 1 3/4 tubes it should be all right,The bolts are sometimes a biootch but doable,Get them ALL started then tighten them down from the outside in,I have some regular bolts and some header bolts with the 7/16 heads for the tight spots.......I soak my gaskets in water over night so they swell up some and seal good I have had good luck with this even tho it seems weird,DO NOT use stock exhust manifold gaskets,You need true header gaskets ,make sure all your speedo,Ebrake,gas lines and cables are up away from the headers so nothing gets melted.................Jerr
Old Jul 2, 2009 | 08:23 AM
A72CUTLAS's Avatar
Tha' Big Dog
.......I soak my gaskets in water over night so they swell up some and seal good I have had good luck with this even tho it seems weird,DO NOT use stock exhust manifold gaskets,You need true header gaskets .................Jerr
Which is the best gasket set? I seem to remember someone mentioning Remflex or something similar to that. Can't find the post, but are these familiar to anyone?
I appreciate the help.
Walt
Old Jul 2, 2009 | 05:57 PM
BIGJERR's Avatar
I bleed Oldsmobile
Walt
Mr. Gasket - Exhaust Gasket Set - 1964-80 Olds V8 330-455 453
Mr. Gasket
Mr. Gasket gaskets are manufactured from a blend of nitrile rubber and fiber for excellent sealing and durability. Precision die-cut for application. Includes necessary seals and block-off plates, where needed.
  • Fits 1964-67 Olds V8 330; 1964-80 V8 330-455
  • Rectangular port - port dimensions: 1.55w x 1.92h
  • Manufactured from cellulose/nitrile comp gasket material
  • Excellent sealing & durability
  • Can be trimmed if necessary for modified ports
  • Complete with manifold end rail seals & distributor gasket
  • Includes steel heat riser block off plates
  • For OE replacement, high performance street, drag race & oval track
  • Two per pkg
Details SKUMRG453Weight0.25 lbsVH SKUMRG453Vendor SKU453UPC Code084041004531Price:$11.99
Heres what Ive used for years......
Old Jul 10, 2009 | 01:19 PM
pross4's Avatar
What are the header options for a 72 Cutlass Supreme convertible? Currently it has 350 ci from a 69 Cutlass with No. 5 heads on it. Sometime when money allows I would like to find a 455 for it.
mal1form
Jan 3, 2007 06:49 PM
69cutty
Dec 3, 2006 04:58 PM
Cuttyon22s
Nov 20, 2006 06:07 PM
84cutty
Sep 8, 2006 12:32 AM
thedude
Jun 30, 2006 01:46 PM
