70 supreme build sheet question
Old Apr 22, 2020 | 08:08 PM
abody's Avatar
I have part of my build sheet For my 70 supreme it’s an automatic 4bl with air conditioning. It has FE for radiator, Has a factory fan shroud. Would that be a 4 core- heavy duty cooling?
Old Apr 22, 2020 | 09:50 PM
4speed455's Avatar
My build sheet is pretty much intact. It also shows an FE radiator. It does not show HD cooling as an option. As far as I can tell it has and has always had a 3 core radiator with shroud.
Old Apr 23, 2020 | 06:41 AM
abody's Avatar
I wasn’t Sure if it was a 3 or 4 core,
Old Apr 23, 2020 | 07:41 AM
jaunty75's Avatar
If you have the radiator, you can tell how many cores (or "rows") there are by removing the cap and looking inside. In the photo below, a 2-core is on the left and a 4-core is on the right. But note also that the cores are different widths. So number of cores alone isn't the sole determiner of how well a radiator sheds heat from the coolant.
I would expect that these two radiators would do a similar job of shedding heat.
Old Apr 23, 2020 | 03:05 PM
abody's Avatar
Thanks, I’m supposed to pick it up this week from the body/paint shop. I will look inside as soon as I get it back. I’m Looking to recore or replace it with an aluminum radiator and change the water pump.
Old Apr 25, 2020 | 09:59 PM
70Post's Avatar
FE is definitely a 3 row radiator.
Old Apr 26, 2020 | 05:29 PM
abody's Avatar
Got it back yesterday from paint, it’s a 3 core Harrison in there, I’m gonna have it re-cored. I assume original, I’m the 2nd owner of it.
Old Apr 26, 2020 | 07:09 PM
Why change the water pump? If it is not leaking, I would not touch it. My car has an auto parts store reman water pump with a stamped steel impeller and it keeps the engine cool during 110+ summer temps. I can't imagine Philly having hot enough summer temperatures to cause overheating issues that require more than what my car has on it.
Old Apr 27, 2020 | 07:35 AM
abody's Avatar
I was gonna change them both, I’ve had the car since 2007, it was in there when I bought it from the original owner. Figured I’d do both at the same time, temps here in the summer are in the 90’s and humid. I will use the air conditioning in it. Figure new belts and hoses too.
GreatSX
Nov 20, 2020 09:31 AM
jpatfarrell
Nov 4, 2018 03:28 PM
Stareyes143
Jun 9, 2017 09:47 AM
Zacc
Feb 15, 2017 04:18 PM
KDW
Oct 3, 2016 02:07 PM
