'70 Olds Rallye Fuel / Brake Lines
Old Jan 25, 2018 | 04:46 PM
Federated52's Avatar
Hi, I was wondering if the fuel / brake lines for my Rallye are the same as a cutlass? Can I order ones for a '70 Cutlass? Also are they fairly easy to replace? (The reason I ask is I would have had to take the body off my GTO to change fuel lines.) Are they similar to a Camaro / Nova? I did replace the fuel / brake lines on a '69 Camaro with little problems.
Thanks for any & all answers. I welcome any advice.
Todd
Old Jan 26, 2018 | 07:37 AM
Todd
Yes. The lines for a Cutlass with the same engine and equipment (ie, A/C or non-A/C, drum vs disk) are the same lines. All Olds A-body cars within a given year and with the same equipment use the same lines.
Old Jan 26, 2018 | 12:49 PM
Thanks Joe. Do the lines run on the outside of the frame, or do they run through the frame at any point? I guess I will figure that out when I get the car home though. Thanks Again.
Old Jan 26, 2018 | 12:52 PM
Inside the frame (for protection from rocks). The fuel lines run through the front crossmember. If you are thinking about installing pre-bent lines, be aware that the factory installed the lines on the frame before the body. You pretty much have to lift the body to install the full, one-piece pre-bent lines. Otherwise, you need to cut and splice or bend and unbend to get them in place.
Old Jan 26, 2018 | 02:14 PM
Well crap, that's not what I wanted to hear. Sounds like too much work for me & probably too expensive to lift the body off just to replace lines......unless it needs to be replaced. Hopefully someone did it before me & don't need replacing. We will see. Thanks Again.
Aug 22, 2019 08:45 AM
Daniel828
Nov 23, 2017 04:04 PM
sawfilm
Apr 5, 2017 05:37 AM
Indy_68_S
Dec 21, 2010 08:58 AM
oldzy
Jan 29, 2010 06:06 PM
