70 Cutlass Convertible Top Cylinder Replacement/Install
Old Jul 17, 2017 | 07:21 PM
Mike70GoldOlds's Avatar
Question 70 Cutlass Convertible Top Cylinder Replacement/Install
Greetings,
Not one but both of the convertible top cylinders is leaking. The top goes down without much of a problem, but going back up, the top needs a good deal of help. I have already ordered new convertible top cylinders and am reasonably sure I can tackle their installation myself however if anyone could give some instruction or advice, I would greatly appreciate it.
I know to use ATF fluid when refilling the pump, and to have plenty of rags handy too.
The only thing I am uncertain about is removing the rear arm rests, I have removed the back seat to refill the pump in the past, but have not taken off the arm rests - how easy or complicated of a task is it?
Old Jul 17, 2017 | 11:18 PM
The side panels and arm rests are held on with several philips head screws and are simple to remove.
Old Jul 20, 2017 | 03:46 AM
Its easy remove rear seat 1st.
kens69olds
Aug 24, 2014 03:51 PM
kens69olds
Jun 25, 2014 07:35 AM
smit4425
Dec 30, 2012 03:20 PM
dougm
Aug 15, 2011 05:05 AM
KevinBN7
Jul 17, 2011 01:02 PM
