70 CS hazard flasher knob and E-brake release lever
Old November 10th, 2013, 12:48 AM
Nop
2-stroke 1-cylinder guy
Nop's Avatar
70 CS hazard flasher **** and E-brake release lever
Hey there.
Already posted to the noob section, but I think heres the right place:
I have two questions regarding E-brake release lever and hazard flasher **** - both of which are missing in my 70 cutlass supreme...
Brake release lever (image #1):
* Is this a GM screw-on T-handle or is it molded to the metal rod?
All I can see is a rest of plastic and some epoxy. Screw-on handles are available here in Germany, but I'd have to order the complete assembly with rod in the US.
Hazard flasher **** (image #2 nd #3):
Mine is missing. There seem to exist two different GM versions:
A) the chrome ones that are screwed in directly
B) the pastic one that has a little nose - apparently to fix it in a position where the text can be read - and seems to be fastened with a center screw.
* Does my steering column look as if only the **** is missing or is something broken?
* What size of thread is that center screw?
* Which one was originally used in my 70 CS?
The black plastic seems right, the little nose looks like it's a perfect match.
Thanks!
Last edited by Nop; November 10th, 2013 at 01:01 AM. Reason: Darn typos. It's noob, not boob...
Nop is offline
Old November 10th, 2013, 03:52 AM
Old School Olds
tru-blue 442's Avatar
Can't help you on the E-brake.
The little chrome button should
be correct for your 70 though.
The threads look stripped from
the photo. Maybe why it is missing?
tru-blue 442 is online now
Old November 10th, 2013, 06:20 AM
Lansing built
1970cs's Avatar
Looking at some of the parts suppliers, the e-brake handle is glued/epoxied
on.
Hazard is chrome on my 70 Supreme! The thread pitch is 6-32 NC
Pat
1970cs is offline
Old November 10th, 2013, 06:37 AM
major noob
billmerbach's Avatar
I thought that maybe the handle was screwed on
billmerbach is offline
Old November 10th, 2013, 08:34 AM
The e-brake handle is actually pressed on. The end of the metal rod has splines that cut into the plastic handle when you press it on to retain it.
joe_padavano is offline
Old November 10th, 2013, 09:30 AM
major noob
OK that makes sense I looked at mine quickly and didn't realize the splines weren't angle like threads but could you not get a screw on one
Old November 13th, 2013, 11:46 AM
Nop
Nop's Avatar
As for the brake release handle:
It arrived today but I was too much of a ***** to press it on - I thought it might crack because of the tight fit.
Tapped an European "M6" thread onto the splined rod and into the plastic handle (you see the tight fit it would have been without thread) and screwed it on. Bingo.
Still waiting for my hazard flasher **** though...
Nop is offline
907delta88
April 11th, 2014 12:33 AM
cutlassdriver61
May 10th, 2013 12:09 PM
JimpeBoy
June 12th, 2011 12:56 PM
HouTXCutlass
January 13th, 2010 10:14 AM
ctrain22
June 14th, 2009 06:09 PM
Quick Reply: 70 CS hazard flasher knob and E-brake release lever
