70-72 Dash bead installation
Old Jun 3, 2022 | 11:05 AM
Funkwagon455's Avatar
I’m getting ready to install a bead on my ‘70 dash that I’ve had for many years. A couple of years ago I unrolled it and zip tied to a straight rod in the efforts to straighten it out as I do not want a wavy dash accent. It came with nine of the plastic barbs that puncture into the dash, which seems insufficient to me. I was wondering if anyone has a better method of application and if you might share any good ideas to create a long term professional result. I had even considered sliding a stainless tig welding rod inside the bead to hold a straight line.
Old Jun 3, 2022 | 11:47 AM
dc2x4drvr's Avatar
Heath, I used the barbs years back, the trim still looks straight, I did slightly reshape the verticals with a heat gun.
Good Luck!
Old Jun 3, 2022 | 11:48 AM
442Harv's Avatar
I had one car where it was glued on. The last one I did I used the little barbed clips and worked fine.
Old Jun 3, 2022 | 02:33 PM
Ap6954's Avatar
I recently installed the bead with just the barbs and it’s straight as an arrow. I used more than 9. Maybe 12-15. Can’t remember exactly. I also Pre drilled the holes for the barbs with an 1/8” bit to make it easier to get them started in. I did like the other user above said and used a bit of heat to get that bend on the sides nice. I think the early build 70 dash beads were glued on. I think there was a dealer bulletin that came out early in the 70 build year about adding the barbs. Must have had issues with the glue coming undone on some cars.
Old Jun 3, 2022 | 05:05 PM
A correction, I did a recount when I arrived home from work and discovered that I actually have 17 to 18 barbed mounts. Perhaps it will be enough to keep it in line. I’m glad that I started to flatten it out when I did.😄
Old Jun 3, 2022 | 09:00 PM
tkcutlass's Avatar
Pics?
Old Jun 4, 2022 | 05:55 AM
Old Jun 4, 2022 | 09:51 AM
Ap6954's Avatar
Originally Posted by tkcutlass
Pics?
Here is a pic of mine done with the pins. As mentioned above if there is any sharp creases use a heat gun before you install to try and get them to lay out. SLIGHT heat! I probably had as many pins as you show on your bench. Hardest part was punching holes in a mint dash pad! Almost as bad as installing friction fit outer trim on a new paint job.
brotherGood
Dec 1, 2022 07:00 AM
gratsoy
Sep 24, 2021 08:55 PM
Ultra Tweaker
Feb 14, 2019 02:38 PM
RG70442
Jun 7, 2013 04:11 AM
66trakpak
Nov 30, 2012 05:23 PM
