'70 442 rear seat belts OE metal or plastic buckle?
The buckles are different depending of whether you have the standard or optional deluxe belts. They will match the ones for the front. Are you SURE your back belts are missing and not just under the rear seat cushion? You might want to pull the back seat out before spending money on new ones.
The buckle in either case, deluxe or standard, is metal. The standard case has a painted black cover, and the deluxe has a brushed aluminum appearance. Deluxe also has a smaller size buckle for the front lap belt, while the standard belts all use the same size.
Standard buckle front, rear, and shoulder
Deluxe buckle, rear and shoulder
Deluxe buckle, front lap
sx455raidercelticfan
December 21st, 2010 08:59 PM
