69 A/C fan R&R
Old Sep 12, 2012 | 05:57 PM
'69CutlassVert''s Avatar
69 A/C fan R&R
Anyone? Need some info on changing out my fan.
Old Sep 13, 2012 | 07:32 AM
Beob's Avatar
Passenger side wheel well has to come out to gain access to the blower
Old Sep 13, 2012 | 08:03 AM
You know I was afraid you were going to say that. Had wondered if I got it up on a lift I could get to it....I appreciate your help with it Beob
Old Sep 13, 2012 | 08:05 AM
BTW brother, that is one nice 442 you got there.
Old Sep 14, 2012 | 07:56 AM
Beob's Avatar
Thanks! Im assuming your fan is not turning on, just be sure it's not switch, fuse or wiring related before you R & R the motor. Good luck.
Old Sep 14, 2012 | 10:03 AM
You know its running but making noise so I wanted to take care of it while i got it down to the paint shop. Since Im going to have to pull an inner fender Id rather do it before I lay some fresh paint on the outside.
Old Sep 14, 2012 | 10:36 AM
Yeah, this is usually caused by the fan coming loose on the motor shaft. Unfortunately it's the same amount of work to get to it, so put a new motor in while you have it apart.
Old Sep 14, 2012 | 10:45 AM
My thoughts too Joe. Called RockAuto and have one on the way for a value on 25.00ish. How could you go wrong? Do it right once!
Old Sep 25, 2012 | 09:11 AM
Guys, just a report, I finally got to the shop yesterday to get my blower changed out. After some thought, and the fact it is stripped down pretty much already, I simply removed the whole fender inner/outer. That gave me a huge space to go ahead and change my shock and coil on that side and got my wheel bearings repacked while I was at it. Overall, very productive day......
The fan's bearing was going btw Joe so I was happy I went ahead and had a new unit to go back with. P00F! Noise is gone. Thanks again guys.
convertible 63
May 9, 2018 06:10 AM
rmoths
Dec 21, 2013 11:03 AM
KZ442
Nov 9, 2010 05:01 AM
agtw31
Jun 23, 2009 01:39 PM
esisson
May 20, 2008 12:09 PM
