68 vent window ? Need answer asap
Will vent windows from a 4 door Cutlass work on 2 door hardtop cutlass ? Guy has a pair cheap and need a set for my car.
Correct. Angle and height are both different. For example, convertible windshield frames are a different height and angle from Holiday coupes.
Also post car vent frames mount completely differently from hardtop vent frames due to the fact that they fit inside the metal window frame on those doors.
OK. I think I have a set of those too. I'll poke around to see what I can find. I understand this post was because you found a set of 4 door ones cheap. But you might consider creating a parts wanted thread if you haven't done that yet. Then see if anything is offered up at a price your comfortable with. John
