68 442 window roller
Does anyone know where to get a window roller for the front window verticle rail for 68 442 convert? It slides inside the rearward verticle rail of the front door and seems to keep the window centered. looks like it might just pop on to a ball stud on the regulator.
Hi Charlie
I snapped some pictures this afternoon of various ones I have on loose glass. If none of these are right I do have an extra 1968 door that's complete. But if one of these is right it would be a lot easier to pull! If you need a better closeup of anything let me know. I have pictures of other wheels but when you described it as looking like it clips onto a ball these are the ones that look like that. John
John,
The third picture looks to be the closest, although not exact. It is the roller that is on a bracket attached to the wiundow channel itself. I took these pictures this morning. Not the best of shots, but the window is in the car. Also, the remainder of the roller itself.
it is the roller that goes on the bottom of that kind of triangular bracket hanging down.
thanks
Charlie
thanks
Charlie
When I did mine I looked under Chevelle parts to get new ones and had much better luck here is an example ... http://www.ss396.com/mm5/merchant.mv...chevellecamino
Doug69Cutlass
May 7th, 2009 08:11 PM
