67 442 Wiper motor removal
Old Sep 10, 2024 | 06:51 AM
bonanzaman's Avatar
I've got the wiper motor pictured here. The washer part is clicking. but not squirting fluid. It's either the diaphragm or housing. Also, the wipers dont always find home and sometimes just stop mid wipe.
If I can get it out, I can probably clean it up.
Can I remove it without much hassle? Do I need to remove the grating below the windshield, or can I detach the pump from the wiper
arms through the hole when I back out the pump?
Dave
Old Sep 10, 2024 | 08:59 AM
Yes, you have to remove the cowl cover to remove the nut that holds the linkage to the motor.
Old Sep 10, 2024 | 09:24 AM
bonanzaman's Avatar
Thanks Joe, I guess. I'd rather not do that. I'll do that later this fall.
But anyways, I removed the part for the washer and the diaphragm is toast. Know where to get one of those?
Dave
Old Sep 10, 2024 | 10:45 AM
Dave
The square motor was used on 67-68 Camaros and all the Camaro repro vendors sell the repair kits and the whole washer pump.
Old Sep 10, 2024 | 10:47 AM
bonanzaman's Avatar
Joe, I just ordered the parts I needed from Classicwhipers.com He's supposed to be pretty good.
Thanks for the reply!!
Old Sep 10, 2024 | 11:18 AM
bonanzaman's Avatar
Just a quick update it was www.classicwipers.com I fat fingered in the wrong address.
The hard part is the diaphragm. He was the only person that I could find that had it.
The Oldsmobile group is great, I don't know how I survived restoring my old 72 Cutlass S back in the early 90's.
Thanks again!
Old Sep 15, 2024 | 11:17 AM
cjsdad's Avatar
You can disconnect with the spring clip, or the nut, but you have to remove the cowl cover to get at either.
I found out during an epic journey in a biblical downpour that a 1/4 inch c-clip will replace the missing spring clip.
RAG
Jul 25, 2021 08:01 PM
Mr Nick
May 26, 2015 07:59 PM
Stevec
Jun 20, 2014 09:46 AM
Big Leche
Aug 19, 2013 12:26 PM
442Harv
Bravada
Oct 11, 2009 03:50 PM
