67 442 Battery Cable Routing Pics
Here is one i took of mine just after tear down started. This is for the 400ci with AT and power brakes. The cable is routed under the steering column in asphalt tubing. Give me a few more minutes and I will send a pic of finished look.
It is important to note that automatic and stick applications are routed differently as well as the first picture posted it great for a stick with w-30 but not without w-30.
What part is the issue you are dealing with the tube from the starter or the upper part by the relay to the battery?
Cable Pics
Thanks everyone for your input.
Another question-
I turn on the parking lights and they work fine, I turn on the headlights and the parking lights go out, Is that normal?
Thanks-again
Dave
Another question-
Thanks-again
Dave
kelly bakies
May 10, 2015 06:38 AM
