66 backup lights
Old Mar 24, 2011 | 09:25 AM
archeryshooter's Avatar
Tony
66 backup lights
Anybody know where the wires feed into the trunk from my backup lights in the rear bumper? 66 cutlass
Thanks Tony
Old Mar 24, 2011 | 09:36 AM
TripDeuces's Avatar
They feed into the wiring harness that runs from left side tail light to right side tail light. There is a hole in the trunk floor just below the trunk lock that the wire passes through with a rubber grommet to seal it.
I have to charge you those fender vents for this tidbit of info
Old Mar 24, 2011 | 09:55 AM
I believe there are two wires, one on each side of the trunck lock. The additional wire goes to your license plate light.
Old Mar 24, 2011 | 09:56 AM
Tony
Thanks Trip I thought thats where they went with the fuel gauge wire or lic plate light than. you will have to do better than that for the scoops though.I built my trunk floor it was pretty bad wasnt sure if I missed something for the wires to go through
Old Mar 24, 2011 | 09:59 AM
Tony
Thanks Tony
Old Mar 24, 2011 | 12:52 PM
Run to Rund's Avatar
The hole near the trunk latch is for the license plate lamp. The pair of backup lamp wires, joined like a 110 volt lamp cord, feed through a small hole in the vertical body panel below the tail lamp that is hidden by the bumper. The hole has a grommet and is about 3" above the pinchweld at the bottom of the quarter.
Old Mar 24, 2011 | 12:54 PM
The fuel gauge sender wire goes into the passenger compartment in the vertical part of the floor in front of the diff.
Old Mar 24, 2011 | 02:37 PM
Tony
OK now its comming back to me I took this car apart in the early 80's THANKS A BUNCH I will start looking to see if I still have those holes or I will drill some new ones I put alot of new steel on it.
Old Mar 25, 2011 | 04:53 PM
The backup wire goes through the back of the vertical 2" above the bottom of the quarter (not 3" as I posted earlier). The crease in the panel is 3" up.
Old Mar 25, 2011 | 05:01 PM
Tony
Is a pic possable? I dont quite get the spot. Sorry
Thanks again
devmar07
Feb 23, 2012 04:40 PM
oldstuff
Sep 13, 2011 08:03 AM
567xbodies
May 13, 2010 06:07 PM
wolfman98
Mar 13, 2010 05:22 AM
67 Cutlass
Jan 6, 2010 05:42 PM
