The 1964-65 F85 inner fenders are the same P/N (588624 RH, 588625 LH). It's possible the Bufords use the same parts, as the wheel openings are very similar. The feature line on the side of the car is higher on the Olds, however, so there's a little difference in the wheel opening in the lateral direction. Unfortunately I don't have access to a Buick parts book.
Hummm,,,,,, dont remember I did post on the Buick Forum asking for the part numbers. If I get the numbers and they match the ones provided by Joe I will let you know
