1972 Olds Cutlass Supreme Convertable
Old Mar 12, 2022 | 08:46 AM
Stuckey's Avatar
I have a 1972 Olds Cutlass Supreme Convertible. It has a 350 Rocket engine with a 4 barrel carburetor and single exhaust. I'm replacing the fuel tank. I ordered a 20 gallon tank but the neck is too short and the back doesn't bolt up with the same bolts. Any suggestions
Old Mar 12, 2022 | 10:23 AM
70sgeek's Avatar
'72 Cutlass ragtop
Where did you get it and how did you verify its fitment before purchasing?
Old Mar 12, 2022 | 10:28 AM
Provide a Part Number and/or a reference to a link/URL which demonstrates which fuel tank you ordered/received so we can possibly assist on addressing suggestions. It's possible they sent the wrong one?
Old Mar 12, 2022 | 11:29 AM
Also keep in mind that the bolts will ALWAYS be tough to get started. That's just life. The straps need to stretch to hold the tank in place. Any minor bends or slight misalignment of the tank in the straps makes it nearly impossible to get the bolts started. I've often had to use a floor jack with a large piece of wood to raise up on the tank enough to get the bolts started. As for the filler neck, as others have said, tell us exactly what you ordered if you want useful answers.
travisbeamon
Jan 17, 2022 01:38 PM
Gixxerg
May 5, 2019 05:44 PM
Josh Pawnell
Dec 23, 2018 11:30 AM
72Supreme4Speed
Aug 21, 2018 11:00 AM
Oldsguy
Jul 21, 2009 06:05 PM
