5qt. vs 4 qt. Pan on stock L69
Old Oct 26, 2013 | 03:11 PM
RandyS's Avatar
I am going to be replacing the beat up oil pan on my L69, and am curious if there is any advantage to putting a 5 qt. pan on it instead of the stock 4 qt. size? The cost is fairly close so it is not the main issue in this case, just wondering about the positives if any?
Old Oct 27, 2013 | 03:27 AM
It holds more oil. I put a deep Milodon pan on my 455 and I'm happy with it. I also put a stock deep pan on my TH 400 when I had it rebuilt.
Old Oct 27, 2013 | 12:29 PM
RandyS's Avatar
Yeah, like Jon Lovitz would say, "then that would be more". Is it as simple as that? Holds more oil?
Old Oct 28, 2013 | 12:38 AM
If the cost is nearly the same then I would go with the pan that has more capacity. That is just my $.02 though.
Old Oct 28, 2013 | 07:13 AM
Chesrown 67 OAI's Avatar
You dont run as much risk of "emptying the contents of the pan" all up top of the engine and starving the bearings with the xtra capacity pan.
400s are notorious for doing this - especially with a bone-stock oiling system - or even worse -- if someone put a high-volume pump in a motor with a standard oiling system. A sure ticket to spun bearings. Go with the larger pan. Lots of people use the TORONADO pan -- good bit cheaper than going with a Milodon or Moroso pan. Now thats my .02 worth -- AND -- "I've been there - done that!!! It aint funny when it happens!!
Old Oct 28, 2013 | 08:21 AM
I probably should have gone with a Toro pan. The Milodon pan I got was over $250. Plus, I went through two leaking Moroso pans before going to the Milodon one.
Old Oct 28, 2013 | 08:41 AM
RAMBOW's Avatar
Ben
FWIW, The cheapo Summit pan I have holds 5qts +1 in the filter.
I think it was $60.
Old Oct 28, 2013 | 11:57 AM
RandyS's Avatar
Thanks, 5qt. it is!
bocoogto
Aug 13, 2020 05:30 PM
pontiactripower.com
Aug 17, 2008 12:51 AM
66cv442
Aug 12, 2008 03:27 PM
bocoogto
May 20, 2008 12:30 PM
bocoogto
Mar 29, 2008 10:00 AM
