'55 front wheel hubs
I found a few companies that sell brake drums for my 1955 olds S88 4dr Holiday. Problem is... No one I can find sells the front hubs for my model. I checked Hollander and no interchange is listed. I even asked some of the drum venders if they knew where to go... No help...yet. Anyone out in oldsmobile world have any ideas? Please, please please. I don't need oem, I just need it to fit.
Just so ya' know...my passenger side front wheel bearings had a blow out and I didn't find it until I smelled something burning. The front bearing housing was trashed, the bearing cup was cracked, the washer was mangled and there appears to be a much larger warped and scared front portion of the hub.
I was coming home and felt a little pull, nothing severe. Thought maybe an alignment. Took a turn, heard some funny noise (not funny ha-ha, but funny oh s%*#). Thought front suspension or steering. No obvious issues. Kicked the tires, jumped in, headed home. Got it jacked up and if not for a cottered nut, the wheel probably woulda fell off.
Old cutlass, I don't know if they can be saved. I was hoping for insight on that. I'd save 'em if I could.
Lone, I'll keep you in mind if need be. I'll see what cards I'm holding and then make a play.
Red, thanks, Ill see if i can't get a message to him in the morning.
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Broke down the broke down
I decided to do a disc conversion. I'm gonna use the Street Rod Garage kit that has everything already in the kit.
Also, upon further inspection, I noticed my spindle was pretty charred up, so I found someone in Connecticut that had a 54 spindle for me.
I'll let everyone know how the conversion went seeing as it seems to be a hot topic at just about any car forum.
DigitalFubar
33
November 20th, 2014 05:08 PM
1Fastolds
Ninety-Eight
22
February 13th, 2014 04:25 PM
