455 manifold
Old Jan 23, 2009 | 11:03 AM
Pete Pino's Avatar
455 manifold
I have a 1971 cutlass that I took out a 350 motor with a 350 transition. I purchased a 455 with C heads. Can I use the 350 intake with the existing 4-barrel carburetor (for now until I can afford to change them) I will change the exhaust because it had single exhaust so I will add the headers now.
Old Jan 23, 2009 | 11:10 AM
dan2286's Avatar
You can not use the intake. The 455 intake is much wider than a 350.
Old Jan 23, 2009 | 11:21 AM
Pete Pino's Avatar
455 intake
What is the least expensive way around this can recomend a manifold? aslo what about the carb?
Old Jan 23, 2009 | 11:41 AM
Eddie Hansen's Avatar
pete I am sure ( at least in jersey) you can get a junkyard 455 manifold on the cheap, I say this because getting one from ebay could be cheap but the shipping would kill you. you would probably be able to use the 350 quadrajet , may not be the "optimum" set up but it would work.
Old Jan 23, 2009 | 12:31 PM
citcapp's Avatar
Check craigslist, I have bought two edelbrock performer aluminum manifolds for 125 to 150 dollars each.
Old Jan 23, 2009 | 12:51 PM
hamm36's Avatar
Lest expensive away around it? Put the 350 back in. Save your self some headaches.
Old Jan 24, 2009 | 12:22 AM
oldsonharmont's Avatar
Be careful with used aftermarket aluminum intakes for the 455, some makes were prone to cracking underneath and then repaired. I found one at a swap meet for $80, but it was once cracked and had been welded.
Old Jan 24, 2009 | 08:31 PM
Toro68
Guest
Posts: n/a
Can you use a 1968Toronado manfold unit? It has a lower profile than rear drive brothen.
Toro68
Guest
Posts: n/a
I have one kicking around
Old Jan 25, 2009 | 06:08 AM
2blu442's Avatar
Pete, shipping the factory cast iron manifold would be expensive due to the weight. If you would post your location there maybe someone on this board close by who has a spare laying around as Toro68 does. John
Old Jan 29, 2009 | 09:32 AM
gearheads78's Avatar
car guy
Its no too bad. Fedex ground will do it for apox $35-40.00
Large size will eat your lunch before weight does.
Old Jan 29, 2009 | 09:36 AM
citcapp's Avatar
I agree, post your location. I have a toro manifold I am not using as well
Old May 17, 2009 | 08:28 AM
Toyaholic's Avatar
It's a sickness!
Just pulled my Toro intake for the tri-power install. If your close to Orlando, come pick it up.
Toyaholic1@gmail.com
Old May 17, 2009 | 09:25 AM
jensenracing77's Avatar
i also have a toro manifold. just let us know where you are.
Old May 17, 2009 | 10:07 PM
442much's Avatar
You can buy a repro at the Parts Place for around $500. They even make repro "D" heads and a conversion kit for automatics changing over to manual transmissions.
the_boat
Oct 7, 2009 11:32 AM
cowboyup1248
Jan 23, 2009 01:25 PM
Aussie67Delta88Custom
Nov 17, 2007 07:36 PM
blue72regency
Oct 27, 2007 09:47 PM
