455 exhast manifold
Captain of my ship
455 exhast manifold
I was wondering if anyone had an "S" style LH exhaust manifold kicking around.This is the one that exit towards the rear . Currently have an X-384785 which exits staight down to crossover to the other manifold 398708-K . I can always block that one off so it just exits rear but the other side would be easier to get around steering box with the "S" style?
http://gawain.membrane.com/~thornton/b_and_c_manifold.html
Captain of my ship
manifold
the only problem I have with that would be the cost...it would be close to around $400.00 CND. Our dollar is not worth much right now and then there is shipping and taxes and brokerage fees. I was hoping to find a used one and then get both sides planed down which will cost me around 30 bucks per.
Captain of my ship
manifolds
I think I need to find out what make and models these came on and start hitting up the junkyards. There is a guy who does all my mechanical work on the van who has a 75 olds with duels , he won't part with it but said he will talk to some buddies. he has a junkyard out back and he also 1/4 miles a 52 chev halfton ( 11.29 ) with small block 350.
The reason the repros are so expensive is because A) it's expensive to make the tooling, B) it's expensive to get GM approval on repro parts, and C) these manifolds are rare and there are no good alternatives.
As far as expense, you have to ask yourself how bad you want the duals. You might be able to cobble up something using a different manifold, but doing that, I doubt you'd save any money over biting the bullet and getting the right part to start with. Using the Thornton piece, everything will bolt up and fit right.
Oldsguy and I used a Toronado driver's side manifold on his 69 Delta 88. We had to cut the back of the manifold off, turn it around 180 degrees and have it welded back on. I don't know if he has any pictures. It worked pretty well for a garage project.
Did the same thing myself....passenger side toro manifold will work but a custom pipe needs to be made. Driver's side will not work....not even close without cutting the bend out and brazing it back together.
OK, I give up. how do you get a Toro passenger side manifold to fit the driver's side? The outlet would point forward and outward, and would likely hit the PS pump. Do you have a photo?
Captain of my ship
bite the bullet
1965-70 88/98/Starfire with dual exhaust. The 1975 car never came with duals but that body would use W and Z manifolds for true duals without cat.
I can post a photo...key is cutting the bend out of the manifold. When done its a short stubby straight manifold and the pipe that needs to be made for it will easily clear the column shift linkage. Flange where pipe bolts must be vertical and not horizontal else ears will hit rag joint on steering shaft....at least the one I did would. Will post photo soon.
I must make a correction. I grabbed the pair I believe to have run duals with On my 72 88 from the rafters of the garage.
The toronado manifold was on the passenger side, and manifold 380001 on the drivers side.
Captain of my ship
455 manifold
WOW I did not expect all of the responses by simply asking if anyone had a spare LH "S" style manifold to fit my 69-455. Some of the creative abilities from those who used a Toronado manifold by cutting out the bend and reversing it was pretty cool to read. Just goes to show where there is a will , you know the rest.Kennybill sent me a photo of the modified shift linkage for the exhaust pipe to clear ( he had tape measure in picture with the linkage) and I compared it to the linkage on my 69 Olds. The lenght of the linkage was the same but the thing that suprised me was that the height of the bend in my linkage was the same from what I can tell. I am somewhat fortunate in that I live close to a builder (Allen Armstrong's who has been rebuilding motors for 40 years and has a great reputation for building race motors ) And the Muffler Boys who can bend and create exhaust to fit. The only problem is getting a manifold to exit the rear at correct downward angle to clear the steering box. I checked the linkage in park all the way down to low and don't see a problem with exhaust pipe clearing that without "hanging low". The rest of the underside on the drivers side is exactly the same as the passenger side so there is no problem hanging duels all the way back. A friend of mine is trying to encourage me to buy headers for it but I am not sure of the possible "bad" effects this may have on my motor.does anyone know if they make "shorty" headers with a rear exit for the 455 and is this a good or bad idea. I am hoping this will spark a similar debate as the info I have gotten so far has been eyeopening informative to say the least.
If you buy headers you will probably blow gaskets all the time. A friend of mine had headers on his SBC and he was replacing gaskets almost once a month. Of course, if you buy quality headers and gaskets you probably won't be afflicted by this.
Still wondering if W/Z manifolds will fit a B body?
Captain of my ship
headers
Captain of my ship
455
yes , it is an X 384785 on the drivers side . it had a crossover pipe which went into the other manifold and then exited out the rear.
Captain of my ship
69 Olds
I was out stripping everything off the block and I just got back in.I was always good at taking things apart even as a kid. Oh crap , I already forgot how to put it back together
#31
#32
Captain of my ship
manual
When i got the car I got a couple manuals with it . I will have to check to see if i have the chassis manual. I do have the Fisher body 1969 service manual here in the house cause I was looking for some body parts , I will have to see if I have the other in the garage. I have been tagging most of the stuff as I take it off. The P/S pump and brackets I did in my garage here so I think some bolts are still in there.
#33
W and Z manifolds are correct for all 1971-74 455 dual exhaust B and C body Oldsmobiles, as well as the 70-74 455 DE A body cars.
They can be used in 75-6 B/C and 75-7 A with a true dual system.
Aussie67Delta88Custom
November 17th, 2007 07:36 PM
