455 engine assembly specs
Old Jul 27, 2018 | 02:44 PM
Rvsmith5's Avatar
So got my 455 cleaned up, painted and ready to reassemble and put back in my 1969 442. I have the chassis service manual to help with it all, but there is a problem, (die hard olds folks already know I bet). I don't have the specs I need in my manual. Is there a 455 manual like a chilton manual or something out there, or do I need to buy the 69 delta88 manual for my engine? Right now I just need basic torq specs, the assembly I think is very close to the 400 in my manual, at least everything looks the same or close enough to figure out.
not against buying another manual, just hope to get more value than 3 pages that I need.
bob
Old Jul 27, 2018 | 04:04 PM
Gascoop's Avatar
Here's a spec sheet I found, might help
Old Jul 27, 2018 | 05:03 PM
RetroRanger's Avatar
72 Olds CS
torque specs listed here not sure if all are covered on gascoops list
https://classicoldsmobile.com/forums...que-specs.html
Old Jul 27, 2018 | 05:06 PM
Rvsmith5's Avatar
Perfect, thanks again!
bob
Old Jul 28, 2018 | 05:50 AM
What "specs" are you looking for? The 1969 Chassis Service Manual covers the 350, 400, and 455. Everything you need for a stock build is there in chapter 6B. If you are using aftermarket parts, that's a different issue.
Old Jul 28, 2018 | 01:51 PM
FStanley's Avatar
I agree, I have even found AMA specs for Oldsmobile with bad specs, but the Olds Factory manual was spot on..
Fred
likethat
Sep 30, 2018 09:36 AM
biggus
Feb 1, 2015 02:04 PM
Sully69
May 20, 2014 09:04 AM
Al Graaf
Apr 3, 2012 05:52 AM
projectheaven
Nov 11, 2008 06:08 AM
