3x2 choke pull off
Old Mar 3, 2016 | 12:01 PM
flatlander442's Avatar
3x2 choke pull off
trying to figure out what i need for my choke pull off. Pictures show a white pulloff and one on the intake," thermostat". Why do you need two? is that the way they came. I have the original choke pulloff that came on the carb and it is all metal, yellow zinc plating one piece,think it is bad can't make it work.would appreciate some advice before i order parts.thanks
Old Mar 3, 2016 | 02:59 PM
You don't need two. The metal thing on the intake is the choke thermostat, NOT a "pulloff". The thermostat is a bimetallic coil that expands as it heats up, moving the rod that opens the choke and moves the fast idle cam. The vacuum-operated pulloff is to help with choke opening under specific load conditions.
Old Mar 3, 2016 | 04:50 PM
3x2 choke pulloff
if i understand you i need one choke pulloff and a choke thermostat. thanks joe
Old Mar 3, 2016 | 05:28 PM
Octania's Avatar
The thermal coil SETS the choke... entirely shut.
Provided the unloader has not been activated by means of WOT by the driver.
Then gradually relaxes to "no choke" as the engine warms.
Immediately after starting, the engine needs just a bit less than "all the choke" and that is when the pulloff comes into play.... as the name implies, it Pulls Off the choke, the exact right amount, such that the first minute or two of operation goes flawlessly.
See if this video works
http://vid19.photobucket.com/albums/...ps3gbb7pnn.mp4
yeah, shows coil snapping choke 100% shut
then unloader as WOT is employed.
How about the first start after 5 months' inactivity:
http://vid19.photobucket.com/albums/...psnqnqmat1.mp4
The pulloff at the right front corner of the carb is pointed out.
Note how it pulls off the choke as soon as the engine starts.
Old Mar 3, 2016 | 05:51 PM
thanks octania. makes sense to me now.
Napoleon1991
Apr 13, 2013 03:41 PM
79Cut2Tone
Jul 12, 2011 05:47 AM
71csvert
Jul 8, 2010 08:25 AM
dynamic88
Apr 10, 2008 07:00 PM
davesdelta
Mar 6, 2007 11:18 AM
