1970 cutlass highcurrent alternator
Old Apr 14, 2018 | 01:25 AM
Bennyluchiano's Avatar
I’m getting some beat in my car what high current alternator do you guys recommend I have the original 350 rocket by the way
Old Apr 14, 2018 | 06:40 AM
How many amps do you need? A stock CS130 with 105 amps is available from RockAuto cheap. More than that and you're looking at aftermarket.
Old Apr 14, 2018 | 08:29 AM
I need more than that I think like 200
Old Apr 14, 2018 | 08:41 AM
RandyS's Avatar
What might you be installing that would pull more than 105 amps???
Old Apr 14, 2018 | 09:42 AM
cdrod's Avatar
Rodney
Benny:
I got a 160A CS-130 alternator from TuffStuff; it has high-output rectifier diodes, a special "iceberg" finned rear housing for better cooling, wider 10mm rear bearing, & high-output stator. Cost me $175. You'll need to upgrade the charging wire and the ground wires to at least 4 gauge to handle this kind of current. Here's a pic and a spec sheet below.
Rodney
File Type: pdf
Old Apr 14, 2018 | 10:25 AM
Originally Posted by cdrod
Benny:
Rodney
that one would be perfect but would it fit my 70 cutlass
Old Apr 14, 2018 | 11:09 AM
cdrod's Avatar
Rodney
Benny:
A CS-130 has a slightly smaller frame size than a 10si or a 12si but the mounting points will match up to your stock brackets. It's a metric unit so the attaching hardware will need to be metric, but the 2-3/4" long thru bolt can still be a 3/8 bolt. I've attached a dimension spec sheet.
Rodney
File Type: pdf
Old Apr 16, 2018 | 08:01 PM
Benny:
Rodney
thanks bro appreciate the help man
442mark
Sep 30, 2017 01:06 PM
HitTheHole
Aug 1, 2013 10:50 AM
capstoneclub
Nov 13, 2010 12:26 AM
marzgtp1
Aug 31, 2009 08:19 AM
marzgtp1
Aug 21, 2009 01:31 PM
