1969 Cutlass s 350 auto 4 bbl quadrajet number and correct 4 barrel intake PN
Old May 25, 2023 | 01:49 PM
69oldscutlass's Avatar
All,
I have a few more items to get my numbers matching 69 cutlass back to stock shape. Does anyone have a parts list with the correct intake and carb numbers -codes etc 350 auto cutlass s . also a good source for head ID numbers and the rest to match codes etc ?
Thanks,
Brian
Old May 25, 2023 | 02:25 PM
2blu442's Avatar
Hi Brian, here's a photo from an old thread. It may be hard to see the code in the picture, but Chris added the number in the top left. Its painted silver but its cast iron. The number 398663 is cast between the carburator and distributor. The number 9 is cast just behind the thermostat housing on the passengerside. The correct carburator is number 7029250 although I've seen some missing the 7 and appear to be stamped 029250. The heads would have a #5 cast near the spark plug, drivers side front most or pass side rear most. The #5 head was also used in 1968. If you really want to get it as correct as possible you may want to look for casting dates prior to the assembly date on you car. That can be found on the trim tag under the hood, on top of the cowl just above the brake master cylinder.
jaylen
Apr 14, 2022 10:17 AM
old greybeard
Mar 14, 2021 09:45 AM
69oldscutlass
Jul 21, 2020 08:57 AM
oldscutty
Aug 11, 2014 05:48 PM
D Appeldorn
May 18, 2008 10:55 PM
