1969 442 headlight install
Old Feb 27, 2023 | 07:55 PM
Carsick's Avatar
I need help on which way the head lights go in. They appear symmetrical 🤔
Old Feb 28, 2023 | 04:45 AM
There are nubs molded into the glass or a metal ring provided that line up with the detents in the light bucket. They are different between high beam and low beam.
Old Feb 28, 2023 | 06:04 AM
Are you talking about the bulbs into the buckets, or the assemblies onto the core support? The assemblies are RH/LH. The easy way to tell is that each bucket has two adjusting screws. The screws go up and outboard when installed on the core support. Note that the base plate stamping has holes for either orientation, but once the adjusting screws are installed, they become RH/LH with different part numbers.
Old Mar 2, 2023 | 05:45 PM
Carsick's Avatar
Thank for all the help!
first30k69hurstolds
Sep 30, 2021 06:41 PM
djsoldzparrts
Mar 26, 2021 01:17 PM
442crzy
Sep 20, 2018 06:58 PM
erik.arnold
May 10, 2015 07:19 PM
Eldomiwok
Sep 23, 2012 10:38 AM
