1968 Cutlass S Gas Vent
Old May 9, 2020 | 02:22 PM
Jimhol08's Avatar
Hello,
I have a question just purchased a 68 Cutlass S and when I went underneath I saw the vents for the gas tank were not there. Just the empty tubes on the tank. Where should the breather run to and what should be on the end of the hose?
Thanks for any help you can provide.
Old May 9, 2020 | 04:09 PM
Yellowstatue's Avatar
The two hoses go straight up to the clip about 6 inches away. '68 only had some strips of foam stuffed into the ends of the hose, whereas '69 had a plastic cap covering both hoses. Make the hoses long enough to reach up to the floor..
Old May 9, 2020 | 07:30 PM
Jimhol08's Avatar
Thank you!
Old May 10, 2020 | 06:16 AM
MI68442W30's Avatar
or you could just purchase the gas tank surge valve as they call it and shove the hoses on it and install it using the factory clamp screwed in place
Old May 10, 2020 | 11:29 AM
rcorrigan5's Avatar
Randy C.
As well, when I restored my '68, I used the original vent hoses with the foam stuffed in them and I was always getting a raw gas smell in the shop. I switched to what is used on the '69 and the gas odor went away. Fusick sells a reproduction set-up called the gas tank vent tube filter kit for about $35 that comes with the filter, tubes and clamps, and that's where I got mine. Looks exactly like the set-up on my '69.
Randy C.
Old May 10, 2020 | 03:42 PM
Jimhol08's Avatar
Thanks for all the help appreciate it
wishful
Tech Editor's Desk
Nov 23, 2019 06:43 AM
Dbechtel71
Jul 1, 2015 12:10 PM
Jetstar 88
Nov 17, 2012 05:40 PM
al714
Mar 17, 2010 09:43 PM
al714
Nov 17, 2009 09:23 PM
