1965 starfire convertible
Old Nov 23, 2013 | 07:22 AM
Bob5973's Avatar
How do you remove the Starfire/Olds scripts from the front fenders, there appears to be no access to the nuts holding them on. Any help would be appreciated
Old Nov 23, 2013 | 07:44 AM
I believe your going to have to remove a few bolts from the lower fender or the wheel well to gain access.
Old Nov 23, 2013 | 08:34 AM
Correct, the fenders need to come off (or at least loose) to reach up and access the nuts.
Old Nov 23, 2013 | 10:26 AM
Bob5973's Avatar
1965 starfire
Thanks for the info, appears to be a lot of work just to change damaged scripts, though there should be an access panel but I guess that would be to easy, oh well.
Old Nov 23, 2013 | 10:48 AM
Access panel? Why? These are not items that wear out and need to be replaced frequently. Keep in mind that auto designers need to balance assembly cost and serviceability with styling and performance. Adding the cost and weight of access panels for every emblem on the car really makes no sense. More to the point, that access would need to be through the kick panels, which would add a potential leak point for water entrance to the interior.
More to the point, try working on a new car sometime, where accessing even normal maintenance items like the starter and alternator require removing large numbers of components. Replacing the starter on our Volvo V40 requires removing the radiator, intercooler, and electric fan module. Accessing the starter on a Chrysler Pacifica requires removing the grille and front fascia, radiator, and front motor mount. Even then, it wasn't exactly easy to get to.
Old Nov 23, 2013 | 02:28 PM
Ancient Iron's Avatar
Those scripts were bolted on before the fenders were hung.
GTI_Guru
Jan 16, 2012 08:18 AM
customcody
Dec 17, 2011 09:24 PM
esisson
Feb 7, 2011 11:34 PM
old-cars
Feb 28, 2009 07:23 AM
petritl
Nov 26, 2008 09:13 AM
