1964 f85 v6 4 speed
Old Apr 28, 2016 | 12:04 PM
starr88's Avatar
1964 f85 v6 4 speed
Does anybody have any idea production number on a 64 f85 v6 4speed, and how rare it is?
Old Apr 28, 2016 | 12:52 PM
Hairy Olds's Avatar
Shoveling Snow
I'm pretty sure Olds did not break production numbers in to these categories. I would think the V6 would not have had the 4 speed option available. But if you have one, it is a bit unusual.
Old Apr 29, 2016 | 05:54 AM
Actually, it was. In fact, in the 1964 model year, Olds offered an F-85 V6 Sport Coupe. Body style number would be 3127.
Old Apr 29, 2016 | 09:21 AM
Octania's Avatar
Last time seen, never
Pretty darn rare
I parted out a '64 with 330 and three on the tree years ago
Before I had the "last time seen, never" rule, so numerous unique features were lost to the ages due to youthful ignorance. Guide your youngsters while you can.
Old Apr 29, 2016 | 11:59 AM
marxjunk's Avatar
In 64 why would it be rare? I mean I've seen dozens of 64 skylarks with v6 four speeds...what not oldsmobiles?...same drive train..
Old Apr 29, 2016 | 12:06 PM
2blu442's Avatar
The member Keener created a post a few months ago trying to do research on 1964 factory 4 speed cars. I think he only got two replies. For whatever reason I don't think they built very many 4 speeds with V6 or V8 combinations that year. John
Old Apr 29, 2016 | 01:07 PM
Keener's Avatar
John is correct, I received very few replies. Some PMs. Regardless, can you please provide me with the build month on the data tag and the frame number and month-day-year stamped onto the frame rail behind the driver side rear tire. A picture would be great! Thanks for your effort.
Old Apr 29, 2016 | 01:11 PM
TK-65's Avatar
With a little math you can figure out how many manual trans 64s were built.
Old Apr 29, 2016 | 01:18 PM
Keener's Avatar
To answer the OPs question. The 4-speed was optional for both the V6 and V8 ending. The standard synchromesh transmission for both the V6 and V8 was a 3-speed. The V6 cars received a 3.23 rear gear, while the V8s had a 3.08 with low compression 2bl option or 3.23 with high compression 4bbl option. I cannot comment on production numbers because data is lacking.
Old Apr 29, 2016 | 01:58 PM
Keener's Avatar
Thanks Jasen, I figured you would chime in with this document. I've added these numbers up in the past. Total F85 production was 176,679 (give or take a few because document clarity was difficult for the Lansing plant), and the difference when subtracting off the Jetaway trans was around 24,547 (again, give or take a few because of clarity with the Lansing numbers). Of the manual trans, there is no way to tell how many were 3spd vs 4spd. A conservative guess would be 50/50. Maybe someone else can review this document to confirm my numbers. I added these up years ago and my eyes were bad then and are no better now. thanks
Old Apr 29, 2016 | 02:01 PM
Keener's Avatar
BTW Starr88, where are you in Colorado. I have one of my cars with a family member in Silverthorne.
Old Apr 30, 2016 | 05:55 AM
There were at least 2,999 cars built with a 330 and 4spd in the 1964 model year...
Old Apr 30, 2016 | 06:51 AM
lemoldsnut's Avatar
I have a 65 F85 post coupe V6 3 speed car. Had basically no options.
Probably got pretty good MPG
Old Apr 30, 2016 | 07:41 AM
Keener's Avatar
Joe, thats a good start for inductive reasoning. Must be the engineer inside you.
Old Apr 30, 2016 | 09:40 AM
2blu442's Avatar
Yeah, I guess I should have started from that point too!
Old May 2, 2016 | 01:39 PM
Diego's Avatar
I may have an answer but currently traveling. Will revisit this if I can remember, or someone can reply and I'll get an email reminder.
Old May 2, 2016 | 02:08 PM
Oldsmaniac's Avatar
My brother has a 64 Cutlass vert with factory 3 speed stick. The 3 speed console was not drilled for the 4spd plate but it was converted to a 4 speed with a saginaw when he got it.
Old May 2, 2016 | 04:21 PM
Diego's Avatar
I haven't really had time to compile documents I've obtained from the GM Heritage Center, not to mention how to read the numbers since they're done in a more unconventional manner than what I'm used to from Oldsmobile.
I do show 5,158 for M20 for F85. Below that I also show the following:
010: 231
100: 370
200: 4,557
That looks like F85, F85 Deluxe, and F85 Cutlass, respectively. Add the three and you get 5,158. So far so good?
The car that Joe referred to is a special sporty F-85 separate from the F85 Club Coupe. It came standard with buckets but only had the V6. If I'm reading this right, only 197 were built with M20. (627 had the M11 3-speed.)
To the OP, please tell me your model number per the VIN and I have an answer for you.
To the rest of yuz, I currently don't know if the tally I have includes 4-4-2 cars or not, but I suspect with more research I'll be able to figure it out. If I could guess, the 4-4-2 numbers are separate, but that we all can figure out at another moment.
Old May 2, 2016 | 05:02 PM
oldolds88's Avatar
years ago my little brother had a 64 f85, v6 3spd on the floor
Old May 2, 2016 | 09:11 PM
64Rocket's Avatar
It has been 20 years ago, but I had a '64 sport coupe 225 v6 4 speed.
On the dash it said F-85 deluxe. Had the chrome around the doors, the trim panel between the tail lights. Also a bench seat, black on black.
Again one of those "I wish I had not sold it"
Gene
Old May 2, 2016 | 09:18 PM
Diego's Avatar
That would be the car Joe was referring to maybe? But I have the impression buckets were standard.
Old May 3, 2016 | 05:06 PM
Gene
Correct. This sheet from the 1964 SPECS booklet shows that the V6 Sport Coupe was in the F85 Deluxe line.
Old May 3, 2016 | 05:11 PM
Diego's Avatar
In the brochures, it isn't characterized as a Deluxe, but by VIN it clearly is.
Old May 3, 2016 | 05:26 PM
Not to mention it's in the same "swim lane" as the rest of the Deluxe models in the chart I posted.
Old May 3, 2016 | 06:01 PM
1964f-85's Avatar
My 64 was originally a 330 2bbl, 3 on the tree, 3027 club coupe, made 2nd week december 63.
Old May 3, 2016 | 08:53 PM
Diego's Avatar
Still waiting for you to answer my question.
From Keener:
Can you post a link of the thread?
Old May 6, 2016 | 04:23 PM
RickSE's Avatar
Wow, a lot of great information here. I should probably put this on another thread but does anyone have any info on 65's? Like 1965 f-85 4-speed wagons? I have two of them and have never been able to confirm any type of a production number.
Old May 6, 2016 | 05:24 PM
Diego's Avatar
Give me the body numbers and I will give you 1964s, which should give a hint.
Old May 7, 2016 | 11:00 AM
RickSE's Avatar
They're both 3635's, so f-85 Deluxe V8, 4d Station Wagon. One is a Lansing car with the "L" code, the other one is from Fremont.
On a side note I got an email from a guy in OR who has a Lansing built 64 4-speed wagon.
Old May 7, 2016 | 11:12 AM
Diego's Avatar
This is what I am showing - help me translate this.
So I think before I figured out:
0 = F85
1 = F85 Deluxe
2 = Cutlass
So "135" would be your wagon, perhaps? It shows 81 built, which is a lot higher than I'd expect.
I'd hate to spread misinformation, but I only show two other 1-series cars (127 and 169) so, per Joe's post above, I think this would be correct. No idea what engines were paired with the 4-speed.
FWIW, 672 had the 3-speed. I don't have figures for the automatics (which would help total the numbers to match total production) but that's simply because I didn't gather the info from the GM Heritage Center.
Old May 7, 2016 | 11:13 AM
  #31
0 = F85
1 = F85 Deluxe
2 = Cutlass
Diego,
That is correct for 1964. The body numbers and VIN changed in 1965.
Old May 7, 2016 | 11:23 AM
  #32
RickSE's Avatar
Great & thanks. The only number I've heard before is less than 200 for 1965 but it's never been confirmed. I'll pass on the 64' number to the other wagon guy.
Mine are both L74 Cutlass engines.
Old May 7, 2016 | 05:41 PM
  #33
2blu442's Avatar
Rick, what part of Oregon is he in? I'm in Medford down in the SW part of the state. Please let him know if he wants to network with other Olds owners there's several of us from Oregon on this site. John
Old May 8, 2016 | 07:45 PM
  #34
Neil Miller's Avatar
2blu442
I'm the guy Rick was talking about with the 64 4 speed wagon. I'm up in North central Oregon near The Dalles
Old May 8, 2016 | 07:49 PM
  #35
Diego's Avatar
Well, there ya go - rare, but prob not as rare as you thought. I reckon with different engine combos, it gets rarer anyway. If that info exists, I don't have it, but it should be in other pages of the document I have from the GM Heritage Center.
Old May 9, 2016 | 01:34 PM
  #36
lemoldsnut's Avatar
Is that the car that was in Prineville and then Redmond a few years ago?
Old May 9, 2016 | 01:37 PM
  #37
Keener's Avatar
From Keener:
https://classicoldsmobile.com/forums...your-help.html
Old May 10, 2016 | 03:01 PM
  #38
lemoldsnut's Avatar
Originally Posted by Neil Miller
2blu442
If this is the car that was in Prineville and then Lyle had it in Redmond it is not a factory 4 speed car.
Old May 10, 2016 | 08:25 PM
  #39
Not sure what car that would be but this one is a 4 speed car.
hardrider442
Non-Olds Engines
Oct 9, 2014 03:45 PM
64oldsf85cutlass
Body work
Jul 4, 2014 07:06 AM
70L34
Mar 9, 2008 02:03 PM
Chas wheel
Feb 21, 2007 12:03 PM
Droptop
Jan 19, 2007 06:09 PM
