1962 super 88 no dash lights
Old Jun 17, 2019 | 10:42 PM
Jeff99's Avatar
My olds has no dash lights, radio, or clock, cigarette lighter. Fuses are good. , gen light and oil light work , turn signals work , interior lights work.. any help would be great
Old Jun 18, 2019 | 06:04 AM
61Bat's Avatar
I would check the plugs behind the dash possibly loose or unplugged. Do you have a wiring schematic?
Old Jun 18, 2019 | 06:24 AM
Jeff99's Avatar
Yeah I do have a wiring schematic, thanks
Old Jun 18, 2019 | 06:25 AM
edzolz's Avatar
Do you have tail/brake lights? Most of the older cars had the rear lights on the same circuit with the dash lights so you would know if your rear lights had gone out. Narrows down the area to look.
Old Jun 18, 2019 | 06:27 AM
Jeff99's Avatar
Yes have brake lights, tail lights, turn signals, and reverse lights
Old Jun 18, 2019 | 08:42 AM
61Bat's Avatar
Cigar lighter has its own circuit direct to fuse box so check for power at the outlet side then at the lighter. loose connection or bad lighter maybe?
Clock is on the same circuit as the instrument lights so I would check the connector there.
Old Jun 18, 2019 | 11:05 AM
One thing at a time. Is the dash pot for the instrument lights turned up all the way? Is there voltage at both sides of the fuse box lamp fuse?
Old Jun 18, 2019 | 12:00 PM
Jeff99's Avatar
Yeah there is power to both sides of the fuses , and yes makes no difference turning the dash pot
Old Jun 18, 2019 | 12:52 PM
ignachuck's Avatar
Frank Ignachuck
As Eric said, one thing at a time. Your schematic is your friend.
Old Jun 18, 2019 | 12:57 PM
Oldsfan's Avatar
The radio dial light is independent of the others. If the radio is not turned on, the dial will not light.
Old Jun 18, 2019 | 01:22 PM
Jeff99's Avatar
[SPOILER[/SPOILER] radio won’t turn on. Is the radio grounded through the Antenna? I noticed yesterday it’s unhooked in the fender,
Old Jun 18, 2019 | 07:58 PM
You need to follow the gray wires under the dash, all gray wires are lighting. Double check the ground side also.
Old Jun 18, 2019 | 10:32 PM
Jeff99's Avatar
Got the lights working it was the headlight switch. Must of been rusted inside. After turning it and a little wd40 it works. And found a wire off the radio so that comes on but no sound at all .. and I don’t think the clock will work. I can’t turn the **** on the front so guessing it’s rusted inside... thanks fir all that help
Old Jun 18, 2019 | 11:07 PM
The radio has a separate ground other than the antenna. If you hear nothing at all I would say the speaker is shot.
73aussie455
Oct 1, 2016 12:34 AM
cmfjay
Sep 16, 2014 04:50 PM
bcg88
Apr 28, 2012 11:02 AM
2 door cut
Feb 15, 2007 01:45 AM
2 door cut
Dec 29, 2006 03:02 PM
