1962 Fuel Sender/Gauge Specifications?
Is anyone interested in helping me to reverse engineer the system specifications for a 1962 fuel sender/gauge system?
I have a 1962 Super 88 that needs the fuel sending unit / gauge debugged & restored. I'm looking for specifications for the 1962 fuel gauge system, so that I can find suitable replacement parts to restore the system.
Specifically, I'd like to know:
1. The range of resistances of the fuel tank sending unit (minimum & maximum resistance values corresponding to full and empty positions)
2. The range of currents that the fuel gauge responds to under FULL and EMPTY conditions.
I'm hoping that someone with a good sending unit could take measurements for me, and that someone with a working gauge could take a current reading with an ammeter to tell me the current going to the gauge under FULL and EMPTY conditions.
Knowing these things, it'd be possible to design a circuit to adapt commonly available parts to do the job of the unobtainable parts.
Anyone?
TIA.
Anyone?
TIA.
Just went through this with a 68. I know at least 66-72 follow this spec.
Range of sender/gauge= 0-90 OHMS
0+-OHMS= empty
90+- OHMS= full
45+- OHMS= 1/2
You can send the sender out to be rebuilt. That is what i did. I tried to source and possibly modify existing things that were available to suit my sender but it did not work out, a PITA
These outfits also can repair the gauge portion also.
0+-OHMS= empty
90+- OHMS= full
45+- OHMS= 1/2
JPMDaddy
January 31st, 2020 04:01 AM
