1960 steering column question
I have a 1960 non-tilt steering column that needs the lower mast bearing replaced. I have been looking all over but can't find part with correct fitment. Seems most applications are '63 up.
Is GM # 7802845 or GM # 5694100 correct? It looks like these, is pressed into a cup on bottom of column.
Just not having any luck. I did tap bearing out of the cup but it has no part number on it. Appears same style as Chevrolet used, but no one can say. Saginaw was sold 3 times since they made these.....
Link is too old for the part CJ found...... eBay is $150/$180, way out of bounds for me in price. Maybe buy whole column in junkyard?
I had a column out of a 60 Pontiac I will check to see if I still have it.
Also have the power seat out of it.
Larry
lemoldsnut@aol.com
Larry
lemoldsnut@aol.com
ros6872
Mar 28, 2014 09:48 AM
