1959 Olds windshield trim
Old Sep 4, 2014 | 09:44 AM
Leroy701's Avatar
Hi, I'm in the process of replacing the windshield on a 59 2 dr ht, the old windshield was broken out. I'm having trouble getting the top and bottom clips to release and havent had any luck finding out how to do this yet.
Does anyone know the sectet?
Thank you
Old Sep 4, 2014 | 11:53 AM
59-59-59's Avatar
The top windshield trim is held in place with a couple 5/16 nuts. I think it was 6 total- 3 on the right side and 3 on the left side
Old Sep 4, 2014 | 12:29 PM
johns59super88's Avatar
If I remember correctly, after you unbolt the top clips and remove a screw from each end of the top, the windshield will push out from the top. Also must remove the cowl screen on the bottom (I think) to reveal the bottom clips which are not actually fastened to the body. This assumes you have both sides already removed. Also easier if you cut the rubber seal all the way around. The manual has a pretty good explanation and illustrations.
Old Sep 5, 2014 | 03:31 AM
Yellowstatue's Avatar
On a '57 the headliner must be dropped to expose studs and nuts that hold the upper trim on...'59 might have a stellar improvement??
fzadnik
Jul 31, 2015 05:48 PM
electra483
Jul 29, 2015 02:57 PM
Oldssupreme
May 28, 2013 05:35 PM
tailfins
Mar 24, 2012 04:53 PM
delta
Nov 2, 2011 03:06 PM
