Does anyone have the exploded view for a 1955 Olds 98? I'm having trouble finding a pinion seal that fits. The one from Fusick and Napa are too large on the O.D. Mine has a race installed and I'm trying to see if it's OEM.
The seal that came out is a Victor 516759 which is difficult to find and not listed for the application.
Fusick and Napa calls for 19438. Thanks Original seal that i removed
Thank you kindly. This confirms that at some point an incorrect seal was put in with a spacer. Probably why it was leaking. With the spacer removed the OEM seal will fit. Thanks again for the help.
