1698 Speedometer
Old Mar 28, 2012 | 01:26 PM
tcarroll's Avatar
1698 Speedometer
Does anyone know if a 1970 Speedometer is the same as a 1968 Speedometer?
Old Mar 28, 2012 | 02:02 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
No different
Old Mar 28, 2012 | 02:07 PM
tcarroll's Avatar
Thank You I appreciate it.
Old Mar 28, 2012 | 04:16 PM
LOL 1698 speedo in the title caught my eye! Chariots and boats with speedos.... hmmm novel concept.
The 1970 speedo IS different from a 68. The general appearance and mounting are significantly different. They were however identical for 68/69 models. The 1970-72 speedos are also identical.
No different
Not sure whether that means they were no different, or no, they were different. That's why I chimed in.
Old Mar 28, 2012 | 04:47 PM
tcarroll's Avatar
My gear indicator is broken on my 1968 Cutlass Speedo. My friend has a 1970 Speedo he said I could use parts from. Is it hard to change the gear indicator with the little spring that is on it. Does anyone know how to do this that can explain it to me so I do not destroy my Speedo? Thanks ...Todd
Old Mar 28, 2012 | 04:52 PM
Well, the first problem is that you didn't tell us what model you're talking about? An A-body is different from a B/C-body is different from an E-body.
Old Mar 28, 2012 | 05:21 PM
Vega's Avatar
Was half expecting to see a thumbnail of some kind of sun-dial looking contraption LOL
Old Mar 28, 2012 | 06:00 PM
umm, Joe - in the thread you quoted he says 'Cutlass'.
Old Mar 28, 2012 | 06:05 PM
tcarroll's Avatar
Yes it is a Cutlass so regardless of what kind of Cutlass it is an A-Body.
Mine is a Cutlass S
Old Mar 28, 2012 | 07:11 PM
Octania's Avatar
To pick nits: among the MANY differences between 1968 and 1969... the cable has a threaded attachment to the '68 speedo, vs a slip-on + clip system for 1969+
However, if the PRNDL needle is its only issue, that's an easy fix.
Old Mar 28, 2012 | 07:16 PM
tcarroll's Avatar
Can you please tell me how to fix it as I do not know how to remove it and replace it with the new gear selector and spring. Thank you...Todd
70 ctls
Dec 8, 2012 11:33 PM
ct1979
Dec 21, 2006 03:08 PM
magnusdog
Sep 14, 2006 01:03 PM
sharkey1967
Aug 29, 2006 11:45 AM
1965_F85
Feb 15, 2006 11:54 AM
