OAI Installation
OAI Installation
I am looking for for some instructions or documentation from an assembly manual on how to install the OAI assembly? Did a search but didn't find anything specific.
It does seem fairly straight forward, but I am not familiar enough to assume anything. Any help here would be greatly appreciated!
Bill
Bill
Clips go on top of valve covers. The OAI top piece (with the foam cushion) has small anchor holes on each side for the springs. Drivers side is easy. Passenger side usually needs some needle nose pliers and a small hand. Make sure vacuum lines are per the diagram also
You got it. In board side of valve cover second or third bolt back from front of engine. Set OAI top piece in place and come directly down from the anchor holes and that's where clip mounts
sx455raidercelticfan
Dec 21, 2010 05:19 PM
