Gauge light bulb replacement
Old Sep 19, 2015 | 06:49 PM
Billyboy746's Avatar
I've got the 70 Cutlass Supreme convertible. Some of the dash board gauge lights are dim....possibly a couple burned out. To replace, do I have to remove the whole front dash or is there an easier way? Anyone done this and how hard is it......what has to be done to replace?
Thanks all!
Billy
Old Sep 19, 2015 | 07:14 PM
oldspackrat's Avatar
Remove 2 phillips screws in top of woodgrain piece & 2 below it where blue lens(es) are. Then you will find 3 1/4" screws holding each gauge in place. The right & left ones will unbolt & pull out with almost no problem. The speedo has a cable attached to the center of it & you must press the tab on the bottom of the cable before pulling the speedo out. Be careful of the harmonica type connector on the back of the speedo & fuel gauge. The pins they attach to can come loose if you pry them roughly or are not gentle with them. Turn the sockets & they come right out & you can see the bulbs in the sockets. If they are real dark looking they are very likely bad. You can test with an ohm meter or 12 volts & a ground. Easy peasy...
Old Sep 20, 2015 | 09:51 AM
Scott, that's one of the best write ups I've seen on this topic! Good job.
Old Sep 20, 2015 | 03:08 PM
Thank you, glad to help.
kansjfr
Dec 7, 2014 05:10 PM
jamac
Nov 24, 2014 05:33 PM
kansjfr
Nov 22, 2014 07:10 AM
gbbarr209
Oct 25, 2014 04:18 PM
Pfiffle
Oct 5, 2009 04:32 AM
