70 Cutlass - steering gear box front seal leak
Old Aug 7, 2015 | 03:29 AM
Del70's Avatar
70 Cutlass - steering gear box End cap seal leak
70 Cutlass Steering gear box front cap seal is leaking. The cap is held in with a snap ring. I watched a video on steering box R&R, and it showed the cap needed to be pushed out by rotating the gear, and an internal piston, then pushed the cap out...after most of the box was taken apart...So can (has any been able to) remove and replace the front cap seal w/o removing the gear box, or disconnecting the shaft. thanks.. and who sells the front seal...
Old Aug 11, 2015 | 04:27 AM
Del70's Avatar
update - rotating the wheel worked for my application - do your research in advance for your application....The housing end cap seal had some bad spots, resulting in the leak. I cleaned the cap (alum.) cleaned the seal area on the housing and put a new seal in. Leak fixed. Was easier than I thought. I think if l had pulled the seal in advance and looked around, I might have been able to find it for a lot less than buying a rebuild kit
allyolds68
Jun 13, 2014 05:28 PM
Redbud40
Drivetrain/Differentials
May 29, 2014 10:45 AM
wmlewis
May 17, 2012 11:37 AM
Del70
May 19, 2010 02:50 PM
dynamic88
Aug 30, 2007 11:43 AM
