12 controllers on epay
http://rover.ebay.com/rover/0/e11021...=exe%2cext=ext
I use these at work
above link says $160 each.
super easy to program- graphically
requires $100 cable though
this model runs on 12VDC
so, you could make a bitchin' anti theft system.
several inputs and outputs
you could disable spark, starter, and/or fuel pump [electric] unless your favorite combination of things occurs- anything you can dream up.
Lights have been on >3seconds plus brakes on
secret switch activated plus brakes off
you could even have the car allowed to idle but not drive away.
I use these at work
I use these at work
I use these at work
